Hi there,
Ive recently had my lc180 leon mk1 re-mapped and just in a few days 2 coil packs have failed..
I hear this can be quite common, is this true?
Any replys muchly appreciated
I had one go while I was overtaking the wifes 85 year old aunt trundling along in her smart car. Was not funny when she overtook me back a couple of minutes later
LOL! my maf gave up whilst driving progressively alongside a boxter s.
they pick their moments
After my remap experiance and seeing the differences in the little things, I'd say before any remap, make sure the following are new.
1. MAF - My maf worked but it made a 3bhp difference for a new one.
2. Fuel Filter - Goes without question
3. Petrol - Coilpacks
4. EGR Valve is clean - again 3bhp more on mine.
About the only reason a remap should knock out coil packs is if the dwell is being whacked up too high and burning the coils out.
You may need longer dwell to stop the spark being blown out, but I wouldnt expect it to need to be so high that it kills coils so quickly. They must already be on their design limits with a std map?
Not true with these engines. If was true then the brand new coil packs would keep failing would they not? Its like a clutch if its been in there a while and worn a remap will finish it off and make it slip with on weeks. Just by adding 3 or 4 psi using a MBC with out any inition advance can knock a old coil out
@ shauncupra
Have you had any issues with the new coils?
