Reducing under engine temperatures
warren_cox
Back from the dead
I've been getting some deformation of my intercooler pipe (front nearside), and wondered whether it was caused by heat under the engine bay or temp within the pipe itself + increased boost from remap.
Having looked at some of the threads on Samco hoses:
a) theyre not that cheap for 0.1% performace improvement
b) Some say silicon content is detrimental to cat and lambda probe
Would reducing the temp under the engine bay help at all? In the demon tweeks catalogue it says reducing the engine bay temp increases power using exhaust insulation wrap. Is this only an useful for cars without intercoolers?
Would it make any difference on an LCR or should I get on the phone to Forge Motorsport and get 2 samco pipes instead?
I know this isn't strictly 'Engine Tuning' but didnt know where else to put it.
:cheers:
Warren
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i'd say do both :p
save power loss and reduce heat with some lagging
nd keep it in tow with the hoses
especially as Forge have a samco sale on @ the monet
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
removing the undertray & under bonnet blanket helped mine no end (oil temps dropped a good 10C)
M
CupraR-Rog
Just Cruising...
Jul 19, 2003
2,291
West Somerset
I think the main thing that's going to be causing the IC hoses hot enough to deform is the fact compresed air is being rammed through them...
OK, so cutting vents into your bonnet may help things, but I think upgrading the hoses is what's needed.
What's this about silicone damaging the cat?? New one to me!! :confused:
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
undertray removal will lead to accelerated power steering belt failure, you heard it here first..
Due to water and dirt getting into and between the belts.
BenS1
3,459
West Sussex, England
Max_Torque done once of his nice technical posts in which he pointed out that silicon hoses actually damage the cat/lambda probes (Can't remember which, probes I think).... I guess the post was in the Samco hoses thread.
Ben
CupraR-Rog
Just Cruising...
Jul 19, 2003
2,291
West Somerset
Ben
Where's a "gulp" emoticon when you need one?? :blink:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Ben
only over a long term use - say 50/60'000 miles
saying that most lambda's need cleaning out or replacing by then anyway
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I have never heard of a Silicone hose being blamed for lambda failure..... othe rthan lambda failure from normal mortality.. (lets face it how could you tell the difference)
Silicon spray however, a la shiney blinging up ya engine bay, can have a detrimantal effect.
Hoses are autoclave cured, and non volatile... but the aerosole sprays are more likely the silicon concern.
Bill
mark sheerin
DUNLOP academy wanabee
May 26, 2002
3,534
www.fastalarms.co.uk
I wouldn't worry about the undertray either....
I lost my undertary when my car was a week old and the right angled lip it has caught over the top of a kerb when I parked.
Have done 60000 miles without it no problem..
I never thought about it but even in the summer and with revo my engine temp has never gone above 90degrees....maybe thats the missing undertray?
Engine bay is a little dusty though but nothing major and no rusty bits.
Jammy
190
Be careful though, Engines are designed to run around the 90degree mark. Running at lower temps can be dodgy. Same reason you dont raz it when its cold.
JAmes
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I thinkt what they're aiming for is lower ambient temperatures under the bonnet rather than cooling their engine
but the point that people miss is that they're looking at the coolant, not the oil!
LEO LION R
if you need to ask . . .
Mar 25, 2002
5,653
on the edge
I thought they were meaning reducing under bonnet temps, to help reduce air intake temps - ie lower induction temps by letting mor eair pass through the eangine bay ?
slim_boy_fat
That doesnt make sense!!
The exhaust manifold wraps are a great idea, as not only do they keep heat away from the engine bay, but they keep the energy in the exhaust gasses which helps with turbo spool up, especially if the turbo is a long way from the manifold.
I am sure my tdi had hard pipes, inface my golf tdi has hard ic pipes as does my 944. Can you get them for the Leon?
