Red warning light beeping three times.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
okay, well obviously this guys has....
youd know if there was a leak as air would enter the system, thus giving spongy brakes, and you would also see the fluid from the leak.
Aug 7, 2009
1,395
Manchester U.K
Brake fluid does not evaporate, its a sealed system. Brake fluid gets low either becuase there is a leak (broken pipe, leaky seal, split/crack hose or pipe, or simply down to friction material wear, as the disc and pads wear, the fluid has to compensate for this wear to keep the pistons in contact with the pad, it is also hydroscopic which means over time it absorbs mositure and the boiling point is lowerd, hence why you would get brake fade or spongy pedal at high temperatures.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Hygroscopic, not hydroscopic - has an affinity for water. You know. like salt . . .
Trouble is, brake fluid is carefully designed to stay stable at the high temperatures that occur in brake calipers under heavy braking. Water will boil, turn to steam (a compressible gas) and make your brakes go all weak and spongy. Which is why you should change your brake fluid every two years, if not sooner.
Hygroscopic behaviour is nothing like evaporation. Hygroscopic fluids will increase in volume as time goes on, from the water they have absorbed. Evaporation will reduce the volume of fluid.
james walker
May 24, 2007
5,121
retford notts
check the geek out... well as i said i ment that, so i think the op has his answer anyways. the point was just because the light has come on doenst mean its leaking, just needs topping up.
basemanuk
scooby to leon
Sep 30, 2008
227
chelmsford
well after trying to read all that science talk i think it is safe to say that the fluid was a touch under the level hence the beeping!
the answer to a few questions is that the brakes are not spongey and have not changed at all.
the reason i diddent check the fluid first is because i wanted some advice from people in here to what the problem maybe hence why i started the thread.
