red steering wheel light
ragz
74
hello peeps
i need your help
got in the car this morning to go work, turn the key and it happens to be that i had a flat battery
rolled it down the street and sumhow managed to get it bump started
one problem
all the lights went off besides the red steering wheel light and steering is heavy as f&%k
my arms are absolutly killing me
any idea were the power steering fuse is
or what the problem might be
plugged it into.a scanner and all that came up was steering malfunction
thanx in advance
Marshall
3,256
Bonnie Scotland
If you turn the car off and back on it should work ok.
The steering will only work when the control unit can see an alternator charge signal and by bump starting it that doesn't happen quick enough.
Sent from my iPhone
ragz
74
the cars starts ok now but red light wont go out
i get 3 beeps before i start the car
Marshall
3,256
Bonnie Scotland
Can you delete the error in the steering system?
I'd imagine it could only be a battery voltage error.
Either that try disconnecting the battery for 5 mins and then reconnect.
If its only a battery voltage glitch this would clear it.
Sent from my iPhone
the wonderful world of electronic power steering. hydraulics where renowned for being on of the most reliable inventions of all time and then they go and replace it with a ecu controlled electric motor. i had a fiat punto with electronic steering and it stopped working due to an alignment issue but the garage quoted me £500+ to supply and fit a whole new sterring column. i however re-aligned it myself.
Marshall
3,256
Bonnie Scotland
You can't put a fiat in the same boat as a Leon!
Punto columns failed on piece probably the most unreliable electric steering ever made.
The reason they moved from hydraulic steering is for price ie cheaper to manufacture with less parts and also emissions as the engine was driving an additional pump etc.
Sent from my iPhone
ragz
74
iv had the battery on charge gor a good few hours
hopefully this will sort it
my battery is weak no doubt
ragz
74
no luck
soon as put the key in ignition i get 3 beeps
car starts fine
ragz
74
I checked with vcds on group 44 and found the next
00003 - Control Module
014 - DEFECTIVE
reset it and it came straight back up
Nath.
The Gentlemans Express
Jan 1, 2006
8,619
16
EASTLEIGH, HAMPSHIRE
Is this not the power steering light that comes on after the battery has been disconnected but goes out once you drive the car round the block
ragz
74
the light your on about is amber and goes out in no time
anyone with any other ideas
thanx for your input lads
ragz
74
jus had the vcds plugged in and noticed the steering angle sensor isnt picking anthing up
steering angle remains at 0 degrees no matter how much i turn the wheel but the angular acceleration fluctuates with my movement of the steering wheel
any ideas lads
seat 240
mine stayed on as well after i had a flat battery and i had to go for a 50m drive befor it turn off. it say in the hand book (if the battery is diconneected or flat, the indicator remains lit, even with the engine running.the warning light only goes off after a distance of 50m)
