I'm looking to do the small service on my 2016 290 Cupra ST, It was meant to be serviced late last year but due to Covid I am been working from home the past year and not using the car at all... like twice a month to just give it a run. So I was in no rush to service it as the oil also looks clean still.
I'm looking to use 5-30w but noticed that you have a choice of long life oil which says to be changed every 2 years?
Oil Link Castrol site
Which one do people use? Normal or long life?
Also read that mk3 are using plastic sump plugs, just checking before I order bits, and it's to dam cold to climb under my to check right now .
LL oil is VW 507.00 spec and was meant for those lovely 20,000 mile services. I would never leave oil in a car that long. I use LL 507.00 but change it every 5,000 miles. Car prefers it and as mine is diesel (DPF) I think it's worthwhile.
Just check but I think you can use either. As you have a Cupra I'm sure someone else can give you a more specific answer.
As for sump plugs. My 2014 uses a metal/alloy one. I believe that post-FL use the plastic one.
Also check here as these guys are very good:
Opie Oils - Automotive Fluids, Oils, Parts, Tools
The UK's largest independent supplier of automotive oils, fluid and parts. We've products to suit any vehicle, from full blown Race / Track weapons, to Daily Drivers looking to save money. Plus FREE expert advice & recommendations - OPIE KNOW OILS
www.opieoils.co.uk
