Recirculating Flap Motor
peeps
99
Hi guys. I have had the following error come up. 00716. I believe this to be the recirculating flap V113. Altea 2.0tdi....
Has anyone any ideas how much this costs to sort? I did notice that the air con wasn't very cold in the summer...sometimes! Thanks
Deleted member 101826
Does the aircon, have a 'ticking' noise when you turn it off? if so think I have to same, no fault codes though
peeps
99
No it doesn't tick. Sometimes the heater motor comes on and nothing comes out of the vents. Then I press the button that puts the air fully on the windscreen and it starts behaving properly and the air flows again.
King of comedy
15
Does your blower work?
The blower can stick on its shaft restricting any operation of the heating and cooling to virtually nothing.
Easy to replace (remove insulation panel in passenger footwell and twist motor anti-clockwise I think - no tools required) but not cheap to buy.
See threads elsewhere for more comprehensive details.
peeps
99
Hi King
yes the blower does work. Occasionally the blower will sound like it is going but nothing comes out of the vents. I then press a few buttons and if frees itself and if works again.
Thanks for the reply, which threads did you mean? Thanks.
