Recall on FRs
_LEON_FR_
131
scotland
Aw well i will find out when i phone on monday my nearst dealer is 100 miles away hope only takes a day might get them do my timing belt its due to be changed as well
G5RBY
White Leon fr tdi k1
May 11, 2012
90
Stirling
I got my injectors and timing belt done on the same time and took about 7 hours.
SuperGreg
I got a letter through too, now to pick which of the shitty seat dealers I actually trust my car with!
sfmk2.
878
If you're on a PD engine, it'll probably be that infamous injector recall.
My CR has no recalls on it at the moment. The only recall it's had done it a fuse of some description, which will have probably been some colour, and some amp-age, and gone into a fusebox of some sort...:lol:
Though when it went in, they laced my back door hinges with lithium spray grease, and proceeded to leave it dripping down the door shuts... the dirty :censored:!
SuperGreg
Mines a 58 plate, apparently they are looking at cars manufactured from 04 to 07, think they're sending letters out to those owners who haven't been in for a check/change of injectors. Mine's going in on Friday.
_LEON_FR_
131
scotland
Well i got send a letter an car booked in for thursday an they said going to check serial number on injectors an change them if required
SuperGreg
Would probably go to the previous owner in that case, but you should be able to drop by the local dealers and ask them to check, depending on how helpful they are your other option would be to phone seat UK, if you search on here the numbers been posted a million times, particularly in the sticky thread at the top 'Leon injector Problems' they'll just need the reg plate to tell you if the work has been carried out previously (a lot have been done) or if its still required on that car.
