Rebuilding Engine (info)
Feb 25, 2007
1,068
cheshire
I haven't desided weather i should go 1.9 is it actually worth it..
I knw the current pistons are fine with the 350 power level i want but the rods are defo on the cars so is the valves..
So in a bottom end there is:
Cranks
Rods
Pistons
Cams
And In the cylinder head i
Inlet valves
Exhaust valves
Anything else
In the head there is.
20 valves inlet and exhaust
Cams chain driven then to cambelt
valve springs
Hydraulic lifters
Bottom end there is.
Pistons
con rods
crank
oil pump chain driven off the crank
Oct 31, 2006
870
Cambs
Best way as you can get what is worn out and keep what could be ok,
£95 is good for a rebore dude, JE pistons are like £560 i think when i was looking a going 1.9 as they are a custom item if you see what i mean, i stayed 1.8 and went for some s3 pistons which were about £400
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
I supose on a Td05-16G it won't be all that Laggy would it..
So i could get the standard AUM piston but uprated the rods to suit? Would a Port & polish Be sufficent?
Id Defo be replacing
Rods
Valves
Valve guides & springs
Timing Belt & Tensioner
Bearings
All Gaskets
ARP HeadBolts
New Water & Oil Pump
Which valves should i replace? Exhaust or inlet?
Oct 31, 2006
870
Cambs
Rods
Valves
Bearings
All Gaskets
ARP HeadBolts
Not to sure on the lag side of things to be honest, yeah you could do the rods to suit the pistons.
I'd replace the whole set of valves myself may aswell so them all at the same time but it's up to you.
Your list is pretty much there mate as what to replace, headbolts should be ok as std items no need to go arp i was told, i'll let you know how i get on!!!
Oct 31, 2006
870
Cambs
yeah think il keep it a 1.8 20vt i reckon...
shall i get new shims or isnt it needed? when i take evertyhing out whats that red grease called..so wen i start to re-assemble everything
Shims?????
Now your asking a question, i'm not sure i was/assumed you just used oil to lube everything so it wasn't dry on intial turnover, i'm sure someone will confirm what it's called
or weather you need it
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Shims?????
Yeah isn't shims that the Crank/cams Sit in ? And i can't get them mixed up
So its just Normal Red Lube grease..
Would LCR Pistons and Uprated Rods Be Ok...or should i just keep and clean up my Existing Pistons and match up with the correct rods...
I could stick the 16g But id have to Peg the torque which i don't want todo...
Oct 31, 2006
870
Cambs
Big end bearings is what the crank sits in which you may aswell replace, could be known as shims but i've never heard it before.
More than likely mate yeah, hopefully my mate will tell me what to get!!
LCR pistons would be ok i'd imagine, i've gone s3 ones as they lower the compsression a little and should be ok for what i want.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
im looking to do this myself as soon as the ibiza comes off the road gonna fit my new cooler and apexi avcr see if it improves my figures and run my gt28rs to its full potential good luck dan will be looking close at this one take lots of pics!!!
Oct 31, 2006
870
Cambs
Should be 19mm yeah but check to sure they match up,
I ain't got my bearings yet as my mate said we might need to grind the crank so we'll get bearings to suit it, so not sure how much they are going be.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Coober I need to know your real name lol,Il be taking loads of pics as thats what a build thread is all about :D
Cupra20: Yeah if i can get a decent price on 82.5 Piston then il be defo goin 1.9 as it does seem a good shout tbh...
Down to tools wise ive got:
210NM 1/2 Torque wrench
Full set of 1/2 sockets
Full set of spanners
Full Set of Torx Bits
Drap TCT Alan Keys
Loads of 1/4 & 1/2 extension arms
Is there owt else i need?
Feb 25, 2007
1,068
cheshire
big end bearings/shims.
034105701007 £16.02
034105701b40z £39.08
head gasket.
058103383Q £27.18
head bolts
06a103385a £15.76
cambelt
06b109119a £20.50
water pump
06a121012x £30.62
exhaust mani gasket
058253039l £4.54
Rc gasket
058103383q £16.03
Just afew part numbers and prices (some prices are at cost tho) i got off my receipts there alot more part numbers and stuff on other receipts but they ether say crankshaft or gaskets so i dont know what they are.
