Rear Wipers
Ringiho
The rear wiper on my Cupra R needs replacing.
I know of the Fabia rear wiper but I would prefer not too change the arm if I can avoid it.
Popping onto the 'Bay gave me this result:
http://cgi.ebay.co.uk/REAR-AERO-Fla...66:2|39:1|72:1683|240:1318|301:1|293:1|294:50
Is this likely to be a direct swap? Does anyone use these wipers?
Edit: Quick thought, would the front version of these be a direct swap too? They seem to be a good idea! The front ones on mine are a bit crappy.
Any info would be great!
:D
LiamUK04
just bought these wipers for front and back a couple of weeks ago, while the fronts are really good, i found the rear wiper didnt fit the arm properly.. and after a bit of persuasion... finally fitted... but then visually didnt look finished (their was a gap between the arm and wiper, hard to explain)... and didnt wipe the back window properly either!... ended up buying a fabia wiper
Ringiho
Thanks for the info. Will try and dig out the Fabia info then. See if I can manage it!
How would you rate the front wipers?
