Rear wiper.
Mr Pig
2,882
1,062
It's hard to recommend a particular wiper brand as things change.
Years ago I used to always buy Champion blades, never had a problem, until I did. Fitted a Champion set that didn't work very well and were shuddering in no time.
I tend to keep old wipers in the shed, in case of emergencies, so I pulled out an old Champion one to compare it to the ones I'd just bought. The difference was obvious. The metal was thinner and the whole blade looked cheaper made.
So I switched to Bosch for years but I've now switched to Valeo because I think they're better. Also cheap. I bought a front pair on eBay for £16 delivered. The dealer wanted £50 for the same blades!
It's worth mentioning that SEAT might fit more than one brand at the factory. It's like tyres, they use what they can get deals on and it's not uncommon for them to use multiple brands. If you buy wipers from the dealer it's Valeo, well it is at my dealer, but it wasn't Valeo that came fitted to the car.
Pinky
216
21
Does anybody know which fitting the Leon uses. I know which brand of wiper I want but they don't do specific fit. Is it a pinch fit?
Big Col
626
89
North Ayrshire
I replaced mine today, the noise was driving me nuts.
I got a bosch item. I would also have happily got a valeo item but my local place didn't have them.
The bosch one is about an inch bigger than the one that came off. Couldn't see any brand one the one I removed.
Enjoy the silence.
Peller
600
191
Edinburgh
I've had the same issue with my current car and the previous car. I just put a cheapo £10 halfrauds own blade on it and works perfectly!
I replaced the wiper on my Cupra SC and noticed that it is an inch longer than than the 5 door (I bought thinking it would be the same size) I couldn't be bothered going back to the shop to change so just stuck with it!
Sent from my Moto G (4) using Tapatalk
Briant566
343
West Yorks England
I was thinking of changing mine can not understand why the 5 door is different are they two marked on the motor factors or Halfords shown as two part numbers
Peller
600
191
Edinburgh
Yep, I thought the same. It was only when I compared the new one to the SC. I even used their wee tablet with my SC number plate and it came up with the same part (109 if I can remember correctly) as previously fitted to my old 5 door car.
Lawtonater9
28
Manchester
Digging up an oldish thread here sorry but can somebody help me out!
I've just bought a Bosch A403 H for my SC, come to fit it and it's fine but it's catching the top of the boot where the centre brake light is.
I'm not sure if I'm missing something obvious or what...
Bought from euro car parts because they have a 33% discount on. Used the reg thingy where you type it in and it even says on the back of the box for an SC.
Measuring the stock rear blade and that's 15 inch but this Bosch one is 16 inch.
Any help appreciated ty.
Big Col
626
89
North Ayrshire
i got the bosch wiper from ECP earlier this year - see my post above.
No issues fitting and none since.
I've dug out my reciept, mines was part number 485776470 if that's any help.
Lawtonater9
28
Manchester
Thanks. I've ordered the same part you did. Not sure why it's catching on the top. I'll take it back and take it from there.
Mr Pig
2,882
1,062
Measuring the stock rear blade and that's 15 inch but this Bosch one is 16 inch. Any help appreciated.
You're in luck, I am a maths genius.
16 is a higher number than 15. Inch is a unit of measurement, a bit like Gummy Bears but a little bigger. That means that something that is 16 inches long is longer than something that is 15 inches.
Let's say you can fit 15 Gummy Bears in your mouth at one time. If someone gives you 16 Gummy Bears and you try to put them in your mouth.... oh oh! Huston, we have a problem. One too many.
That's the problem you have here, you have one too many of those pesky inches. Just take that bad old inch and throw it away and you're golden :0)
Lawtonater9
28
Manchester
Ok I'm just gonna say it's abit sad you've sat there and typed all that but if it makes you feel better then ok.
Do they call u Mr pig because you look like one or what?
Stevan
96
Musselburgh
I went BOSCH 3397008713 / A331H AEROTWIN REAR
On an ST MY2016
Yes the judder / sticking noise on the original was horrible. No problems since. Can still hear the wine of the motor or something though.
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
I've disabled auto wipe when selecting reverse as it would scare the sh1te out of me when slightly damp causing it too judder and not expecting it! Took years off me too many times lol
hybrid713
15
So glad I came across this post, thought it was just my Leon FR (65 Plate) that came with a dodgy blade. Will look into the Valeo, thanks!
hybrid713
15
I've had my car for 2 years and it's my first car so not much experience with changing or doing anything to my car apart from filling up the tank! Am I right that changing the rear wiper is a straightforward job and just google / watch some youtube video? Or best to get someone from Halfords to install it?
Webstuff72
481
101
Milton keynes
When it comes to car maintenance we've all started from knowing little or nothing..
Changing the rear wiper is one of the easiest things you'll do on your car.
You see this square on the wiper, simply push it down and wiper will slide out... Push the new wiper back on and it'll click into place..... Job done...
