Rear Wiper Fabia Coversion Failure
stuee
52
S.Wales
Just tried to fit the Fabia mod- (Ebay Item number: 110797290917)
Part Numbers in kit
6Y9955707A – Fabia Estate Wiper Arm -
6Y0955425 – Fabia Estate Wiper Blade -
6Y6955435 – Fabia Hatchback Wiper Cover -
:help: I've seen several referances to this successful mod on these forums and wanted to rid myself of that noisy, awkward rear blade too. Is mine the only Mk1 leon with the washer squirt coming from the wiper hub ?:confused:
Thus making this mod impossible or can it be modded itself:shrug: :think:
I will try to add pictures to explain but would like some quick help please:help:
BTW-Car was imported new from Holland and specced to SE+ uk spec
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
Guessing you got the estate wiper cover by mistake. They dont have the washer jet in the arm
Dannyh
The Black Pearl
Dec 30, 2011
372
Manchester
I have the fabia conversion and its fine. the cover as said above should have a slit in it to allow the jet to squirt out, you could just modify the cover you have by cutting a slit in it
seantdi
no smoke no poke!!
Jan 18, 2009
1,218
ireland
Double check that wiper cap that you has the same part number as you listed above. When i was getting mine from the dealer he gave me an estate cap but just mentioned that i had the wrong part number for it. He just assumed i wanted ir for a fabia estate!!
stuee
52
S.Wales
Yep It is the wrong cover
Mentioned to the ebayer and she's sending me another (right) one in next post -good girl:)
easy mod to do too only takes a few mins- Old cover's a bit brittle tho..
Thanks for the info guys.
Will look [B)] with the flat blades on front too
