rear washer jet
Pacey
258
Northants
Sorry for taking so long boys and girls hope these help and explain all! if you need any more help or have any questions just ask!
[/IMG]
[/IMG]
Undo these two screws
[/IMG]
[/IMG]
Pull carpet back
[/IMG]
Pull apart top part that the parcel shelf clips on to so you can get in the gap to get to the hose
[/IMG]
You should see this white hose
[/IMG]
and here is were you need to clip it back in to the black connecter
[/IMG]
and one last view from further out!
[/IMG]
Hope is helps :D
Pacey
Deleted member 20376
thats what i wanted nice one. i noticed there is a third screw . to get the whole thing off and it should pop off easy enough. if you pull ya back seat down there is a screw there and the whole thing comes off. a lot easier to get in at the clip.
mines fixed 2, although i did find another screw that takes the whole thing off saves you cutting yaself. push the back seat forward and you will see the other screw. easliy clips off and easliy goes back on.
jamandspoon81
239
i had the puddle in the wheel arche too,so i followed what you said and found that the pipe had come off,waho sorted,erm no!!
it then leaked from the boot lid,so i took all the plastic off from the boot lid and found the pipe had come off where it goes into the motor arm,so i popped it back on,yippie i thought,its fixed,
nope again,it now sprays the rear windscreen but it also fills the boot aswel,it just pours back out where it goes into the arm/motor,any ideas for a reason why?
cupra-rich
423
coventry
sounds like the brass pipe that is inside the wiper mechanism has broken. need to replace wiper motor £50ish from gsf. real easy to change motor only 3 bolts straight swap. good look with getting boot cover off and back on with out snapping any of the fixings.
jamandspoon81
239
yeah it sounds like you could be right then,i had the cover off lastnight,what a bitch to get back on!!! thanks anyway
