Rear Washer Again!
luig
I have done a search on this and found lots of similar problems but none that mention how to fix it, just states 'fixed under warranty'.
I think the pipe has come off the rear washer (water going into boot and not on window!).
How do i remove the rear plastic panel inside boot lid to get a look. I can find the two torx screws under the rear light panels but what else? :confused:
luig
Think i know what the problem is. I have checked the pipe and thats ok, the leak is coming from inside the wiper unit itself, so i have taken apart and narrowed it down to the connecting pipe that runs through the wiper unit.
Hopefully if the link below works its parts numbered 19 and 20.
But as you can see from the list, the part number for these are not listed.
Any help?
http://www.vagcat.com/epc/cat/se/IB/2003/254/57/4743444/
I have just tried the link and it only opens up the page if you have registered with VAGCAT.com.
luig
I think this might be the solution for my problem?
Has anyone used one of these kits?
The stealer wanted £205.72 for a new wiper assembly which includes the motor!
You can't just get the part I wanted, SEAT only sell the whole assembly.
The kit above is £22, from vagparts.
