wheel alignment settings for Stylance 2.0 tdi dsg
car going in to have alignment check on Friday pm. NSF Pirelli P7 tyre 225/45 x 17 91W replaced in August 08 at 19000 miles as was down to limit, but with even wear. OSF at 22000 miles still has a few thousand miles life, being replaced also on Friday.
Would really appreciate it, if i could get factory settings before then.
Chassis no: 1PZ 7R 058787  07 model year with 17" rim option
At least this would be a start, as many warranty issues still unresolved since new built November 06.
Now : Rear brake pads 70% worn at 19600 miles (August 08 service) yet fronts still have plenty of meat.
Official response from Seat Technical today was: not aware of any concerns of this nature. Brakes are wear and tear components and wear in accordance with driving style. Impossible to predict how long pads and discs will last.
I have never know rear pads wearing faster than front before in 36 years of driving. I only wanted to know why and what could be the possible cause, brake bias or a faulty cylinder? Car is a diesel, so would have thought that bias should be at front first?
Also diagnostic check showed no fault with engine, yet after 50 tank to tank checks average mpg still not reached 41 mpg. Has had 2 replacement turbo`s in first 8 months within 6900 miles and EGR valve stuck in June 08.
I am not at all happy, as I don`t drive car hard and now stick to 60 mph max, otherwise consumption drops and is somewhat erratic.
Also had rattle from behind air vents since day one and still not fixed. In cold weather vibrates all the time and dealer has heard this, replaced centre vents but did not cure. Today no fault found! Was not cold enough, but I can reproduce just by putting a/c on low
Now losing faith fast in Seat UK, as was promised in August 07 that all issues at that time would be resolved. If only!
Thanks in anticipation
