i run 15mm eibach spacers with a 7.5j x 17" width wheel running 215 daps, rubbed once over 1000miles at high speed 130mph hard corning with 2 of us and luggage inside. i do run coilover though.
sorry to hijack your thread lads, just reading through this, im looking at getting 18" rims on mine but dont know if they will fit, what tyre size should i get? 30/35? im running coilovers with 15mm spacers
If only 30mm you'll get away with 15mm spacers.
I'm running 15mm on 17's and prob -50mm at least with no rubbing
Do n ot go near those delta spacers for the mk3 they are shocking! Had terrible noises when I fitted mine, so did Acidstrato and a few others. They are currently sat in my garage, I now have the eibachs. Should of bought properly in the first place!
I have delta spacers and to start with I was getting vibration from them as the center bore wasn't fitting flush with the hub face. I had them machined by a friend of my dad and they fit perfectly flush now with no problems. I know Eibachs are the best but these cost me £25 so I'm happy to use them for now
