Rear screen washer
Snowsurfer
62
Has anyone else found the rear screen washer is pathetic ? Picked my 57 Cupra up yesterday and the water litterally shoots 2" up the rear windscreen if that. Cant see anything obvious blocking it.
pacm0n
113
DERBYSHIRE
Hi,
Nope I cant say I ve noticed, I thought the front and rear washer jets where good.
Have you tried sticking a pin (or similar) in the jet hole, the smallest piece of dirt may be blocking part of the jet?
Dont want to state the obvious but have you also made sure the washer bottle is full?
RodneyA
FR crazy
Nov 14, 2008
102
South Africa
Hi,
that is a good question...where is the bottle for the back window washer?...is it linked with the front bottle?
in my other cars, it was in the back.
thanx,
RodneyA
RodneyA
FR crazy
Nov 14, 2008
102
South Africa
one last stupid question, where does the soap go?..do you mix it with the water?
on our ex Fiesta ST, we drained all the water from washing the windows.
poured water in and sprayed...soap appeared...weird.
thanx,
RodneyA
erichuyn
Newbie
Dec 25, 2005
194
Netherlands
thanx,
RodneyA
Euhm all the cars I've had so far only have one bottle. But just in case, YES the one under the bonnet is the only one.
Mine sprays almost all the way to the top. Only problem is that is sprays in the middle, which means the wiper goes through the gunk first and then reaches the fluid.
And since the Leon gets it's rearwindow dirty very fast [:@]
Snowsurfer
62
Hi no i havnt tried a pin but did try and look into the nozzle. Washer bottle is full, so guess i will try a pin tomorrow. Checked in the boot too just incase there was a leak and cant see one.
pacm0n
113
DERBYSHIRE
thanx,
RodneyA
Its always best to use a screenwash. Just put it in your washer bottle. Or if you use the concentrate follow the instrctions on the back of the screenwash bottle.You can get it from most garages, supermarkets, hardwear stores. Always some in the car and vehicle section.
RodneyA
FR crazy
Nov 14, 2008
102
South Africa
@ Snowsurfer - utilizing a pin usually solves the problem...so i'd surely give that a try.
if thats doesn't work...then only do i think you might have an issue.
@ pacmOn - will bear that in mind. thanx!
dannypea
Hi there Snowsurfer,
I had a similar problem a couple of weeks ago when the rear washer lost all pressure and was hardly spraying any screenwash at all. It turned out with a bit of investigation that a connector in the boot on the passenger side of the car had popped apart from the hose as I had tried to spray the rear windscreen when it was frozen, so the water was just pumping out and leaking into the boot. Try feeling for dampness in the boot on the left-hand side which could indicate the same problem. If it is, it wasn't too difficult to fix in the end if it's the same thing. Hope you get whatever it is sorted anyway!
FR Scott
I have also had a recent problem with the rear washer, it completely stopped working. I could however still hear the pump/motor thing and there was plenty of screen wash in...... on investigation it turned out the hose had come disconnected in one of the rear wheel arches! Maybe worth a quick check to see if there is a bit of a leak.
foxy367
198
Wigan
As above but the pipe to my washer was drivers side close to the rear seat belt. Check the seatbelt too that was damp when you pulled it out, had to be double jointed with 2" thin arms to get at it it was a right pain! :censored: It might depend on the year or the Seat usual odd ways of building cars and spec lottery as to where the pipe is!!!!
/dev/null
1,649
101
My rear one is fine but I find the mist from the front ones isn't always adequate in winter conditions like when the road is very salty. I find it sometimes just mixes the water with the salt, smears it across the screen and then dries making it even worse, lol!
Snowsurfer
62
Found why its not working properly when holding it on for a longer period im getting water spill out from under the car. So something has come apart/split. Cant seem to find where though so guess its a trip to the garage to get it on the ramps.
ade1lung
mine is doing the same from my ibiza mk4, water for rear washer coming out from under the engine bay, so let me know what garage say so i can try and sort it out, i hope its just popped off the water tank!
good luck:D
Dec 15, 2007
1,143
South East London
Just a note, couple of mornings this week my rear washer wouldnt work first thing, obviously frozen up somewhere, so be careful not to use it too much when it is really cold or you might burst a connection somewhere!
Dec 15, 2007
1,143
South East London
Ive noticed that too, bloody annoying! I have a bit of windscreen OCD has to be spotless :whistle:
ade1lung
i have once fixed the rear connector in the boot after that popped out and i had a nice little swimming pool for ants in the spare wheel well!
gonna get the wheel and arch liner out on sat to see if i can reconnect it, if not then off the the garage we go!
