Rear Lower Bushes?
JR750
95
Hi,
Just got my tracking done and they did a free health check and recommended that it get some rear arm bushes, said they couldnt do it as they didnt have a 'special tool'.
Is it only SEAT who have this tool? Anyone know roughly the cost of replacing them?
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
try and see if you still have the void bushes (considering you don't have a cupra)...if so then SEAT should replace them for free
mention that the standard bushes were declared as VOID, see how you get on
JR750
95
How would i know if they are void ones? Anything specific to look for?
It is a 2003 TDi SE with 58k on the clock.
gus
476
are u talking about the lower arm bushes. (consul) ?????
JR750
95
yes. ATS Euromaster couldnt do it as they didnt have the tool, suggested I take it to a SEAT dealer. Amma gonna be ripped off? :cry:
gus
476
yes u will, i got a quote for thsee to be done and they said £225, just bought some cupra ones and a vag mechanic will be doing this for me alot cheaper. where abouts are u in the uk??
JR750
95
North Wales.
What do the bushes do anyway? It passed an MOT 2 weeks ago so hopefully they are ok for now?
gus
476
it holds the lower arm in but it wouldnt come out anyway, but when this is worn it will create movement in the wheel when there shouldnt be. if u go to the from of ur wheel and try and push it backwards with ur foot, there shouldnt be any movement at all. mine has cos of those bushes.
NickyJam
Mar 17, 2008
1,669
SW LONDON
the bushes just prevent movement and knocking at any mounts/joints such as engine mounts, wishbone mounts...obviously to prevent damage as well
i couldn't tell you what the old one's look like...all i know is that the newer bushes have a web design and have a longer lifespan than the standard ones, had my fronts & rears replaced under warranty when I complained about knocking noises
joop200789
330
Barnsly
ive literally just fitted some to mine not 2 hours ago,using a vice and my persuading tool lol bit of a ball ache tbh, the speacail tool would have been easy (a threaded bar with two cups on the end) or a press would do the same
also you'd be better of getting the cupra ones there a full soild rubber bush, and arnt really any dearer awsome gti sell them on there site about 16 a pair,
on where like when you tapped the throtle it gave a big twich in the steering wheel like you where getting torgue steer
RUM4MO
7,967
1,059
South Scotland
The original TCA rear bushes fitted to all the Fabias, Polos (9N) and Ibizas (6L), except Cupra, were voided bushes, this means that there are holes or voids through them to make them "soft" while still being able to control the movement of the front suspension TCA. When the new Golf arrived, it came with a similar TCA design, but it had 4 webs where the smaller cars had two, it seems that VAG have now decided to got that design of bush on to the Fabia, Polo (9N) and Ibiza (6L) except Cupra. Cupra gets a solid rubber bush with an outer aluminium skin so it is not so easy to fit into the aluminium consoles - there is a danger of cracking them if you are clumsy. The smart money is to NEVER replace any voided bushes with anything other than the Cupra bushes - I got a VAG indie to change the bushes on my wife's Polo 9N a few years ago and they are still as good as new and the "feel" of the steering etc is far better than with the voided bushes. The high cost of fitting these bushes at the VAG dealers will include a full four wheel re-alignment as they remove the lower cross member and consoles - as will a proper VAG indie, if a VAG indie gives you a seriously low price then I'd doubt if he has the kit to carry out the full four wheel re-alignment and might say that its not necessary - this is not true and you will pay with extra tyre wear and end up with a car that feels and drives like a crab (I've never driven a crab though!).
