Matt
Ok they're not as bright as the originals but they do look good.
The ebay T5's do need to be modded a little.
The lip represented by the green line needs to be cut straight down or as near flush with the inner part as possible. This is easily done with a sharp Stanley blade or craft knife.
The lug represented by the red line needs a little trimmed off vertically so it can also fit into the circuit board holder. Now do this little by little so it just fits in as once in you can't really turn to lock them like the originals. However as long as it's a tight fit and the little bits of wire make contact with either side of the board then the light will come on. I also used a little electrician tape to hold them in firm.
Don't forget if they don't light up first time they need to be taken out and turned 180 degrees. Then try again. Remember don't take too much material off on the vertical cut has I had one side looser than the other.
The green line lip can be cut flush as with this it doesn't even fit in the board, or it didn't on mine.
HTH
