anyone know a good rear brake upgrade (using VAG parts) for the leon cupra??
vee_dub_modder Volkswagen racing tech-pt Feb 19, 2008 406 0 Midlands May 19, 2009 #1 anyone know a good rear brake upgrade (using VAG parts) for the leon cupra??
olliep Wants a mk2 GTI Oct 3, 2005 709 1 Winchester May 19, 2009 #2 r32? or just upgrade to an LCR (thicker vented disks)
BCM Keyboard Gangster Feb 1, 2005 2,680 0 Wishaw, North Lanarkshire May 20, 2009 #3 Any reason? Sure most will tell you if you've got a good set up on the front then the rear really dont do all that much. R32 or similar are prob the best idea.
vee_dub_modder Volkswagen racing tech-pt Feb 19, 2008 406 0 Midlands May 20, 2009 #4 BCM said: Any reason? Sure most will tell you if you've got a good set up on the front then the rear really dont do all that much. R32 or similar are prob the best idea. Click to expand... mostly to fill some space in the rear wheels... i've got room for a small familt between the rear disc and the rim lol
jwfcms Active Member Sep 14, 2008 384 1 UK Yorkshire May 20, 2009 #5 lcr ones but they still look small compared to the fronts..but still look better a bit bigger and vented
