Rattle!
Chriswaite130
Byebye TDI, Hello VTEC y0
Jan 24, 2008
579
Northumberland
Hi guys
I know Ibiza's are known for rattles but this one takes the biscuit. Its coming from the footwell/behind steering wheel. I just cant find it! Tried removing the little cubby hole thing (on the right hand side of steering wheel) and tried removing the panel above the pedals, but that isnt it. Sounds like a plastic clicky noise.
Had a quick searchy, but cant find anything. Anyone else has this problem or know what it could be?!
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
i've got 1 that seems to be behind the steering wheel...but its just the dash rubbing where the main dash meets the part around the dials. just a Seat thing
Altech
Ibiza PD170
Oct 3, 2007
1,996
London
I've got exactly the same noise as you've described! I'm going to try n solve it by shoving a bit of foam or rubber in the gap.
Chris - to find out if you've got the same rubbing noise....push the instrument cluster when you hear the noise and it should stop.
lc4geoff
FR TDI
Jan 12, 2008
205
Portadown, N. Ireland
My car was in the stealers because the boost pipe blew off and it was getting fixed under warranty. When i got it back, there was a rattle, turns out they hadn't tightened the airbox up properly, check that yours hasn't worked itself loose.
LoDa
136
Southampton
As you are going along, see if you can put pressure on different parts of the dash to stop the rattle. Then do as Altech said and hopefully that = fix. I still get horrible whistles on the motorway, its a seat thing
Dr Gav
hello mate, i had several rattles on my mk3 ibiza so i tore the glovebox out and the speedo and the steering wheel, upon replacing them (and putting in some missing screws) it stopped apart from the glovebox. i was later told to cable tie down the loose wiring as this could cause a rattle . . . . go figure:confused:
Chriswaite130
Jan 24, 2008
579
Northumberland
Cheers for the replies guys, iv taken out parts of the dash and tried tying loose cables and putting pressure on different places but its still there... the search continues! lol
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
very often the rattle will come from the other side of the car from what you think.
Get a passenger to tell you where they think the noise is from, you may be surprised...................
