Random on/off interior light
Solo
70
14
About once every 5 or 6 weeks, I'll be driving along normally and the front interior lights come on by themselves. I have a 2023 e-hybrid and the car is used pretty much every day.
I tap it to turn them off and within a few seconds they're back on again. All OTA software updates have been installed but with such a random issue I can't see how it would be a software problem. I've also tried cleaning the light lens.
Has anyone else experienced this and was there a fix? I know what'll happen if I take it to Cupra: 'unable to replicate fault', unless it's a known issue.
I didn't really care in the summer as I was rarely in the car when it was dark. But now approaching winter, it'll get annoying driving around in the dark with the interior light on.
cairus
1,285
458
is a known problem. There is a TPI for it. So go to the dealer and have it exchanged under warranty. If the warranty is still valid.
Reactions: Solo
tomek_olo
Cupra Leon ST VZ 2.0 245 DNPA DQ381
Jan 28, 2022
133
44
Roof panels are faulty. Mine was replaced under warranty due to SOS warning. As it appeared - touch controls were also not working.
Reactions: Solo
Richiepoos
138
47
Mine did this constantly on a journey to Liverpool back in July. Parked it up overnight and the lights were fine...however, the sat nav decided that it doesn't want to talk to me and has been silent ever since!
Nov 10, 2024
19
Happening to me here in Australia with my Leon VZ. Seems to happen on a really hot day, when I’ve got the aircon running too. It works perfectly fine otherwise, but I will bring it up at my first service, although I doubt they’d know much about it since Cupra have only been here with limited visibility for ~3 years.
  • Sad
Reactions: Syphon
Richiepoos
138
47
I did have a thought that it might have been the air from the vents triggering the touch sensitive lights? I had the vents angled upwards...grasping at straws?
Solo
70
14
I thought it might have been greasy fingerprints triggering the touch activated lights. But wiped clean it still happend, albeit hasn't happened for over a month now.
Definitely not something I'm going to get looked at as previous experience of dealers looking into intermittent faults has been more hassle than it's worth.
Nov 10, 2024
19
Had mine replaced under warranty. Video provided wasn’t sufficient for a warranty job, so they had to fluff it a bit so that they could get it approved for a warranty job. Been about 3-4 weeks so far and it’s working perfectly. The previous unit used to stick out a bit towards the front, a noticeable gap, and now that is gone and it’s flush. I suspect the wrong unit was originally installed or not installed properly.
Solo
70
14
Weirdly it hasn't happened for months and then it did it again today. To the point that both left and right lights were on and I couldn't turn them off. Was during the day so not too bothered. They went off when I parked up and turned off.
Still not significant enough for me to bother pursuing a dealer. It's a lease anyway so will be going back in 3 years.
