Can those who have fitted auto wipers and lights to a facelift please let me know if you have the faults mentioned in the above posts when carrying out a scan after fitting.
Jim
I had 2 error codes when i installed this. One was about the sunlight sensor and the other i can't read with my HEX-USB-NET cable
I managed to clear the sunlight sensor by changing this option to not installed.
channel IDE08786-ENG124476-Assistance light functions-Sunlight Sensor
I think its coded to look for the sensor otherwise
Hi Jim - no the sunlight sensor is already installed in the car and is not part of the RLHS.
It’s underneath the grill of the centre speaker atop of the dash.
Just gone through the coding although I still have the Chinese Auto light sensor fitted as my SEAT Auto switch has got lost in the Dutch postal system. I have de-activated the sunlight sensor as suggested.and now have one error left which I can clear but comes back on the next scan, any ideas?
I believe this is probably the error i have that i couldn't read. No idea how to fix it though
OK, interested to see if anyone else gets this error after the mod and have you managed to get rid of it permanently?
B
Nope. If i try to clear it it appears again immediately
Can we test the sunlight sensor, after installing rhls and autolights? I have noticed sometimes my headlights come on when its sunny.
Sent from my SM-G930F using Tapatalk
Yeah i disabled it, right now i dont get any errors. I think everythin is working fine.Did you disable the sunlight sensor when you coded the new parts and do you get the same error as I do (see above)
I dont know if the motorway lights are working properly (apparantly the light sensor and speed is combined to control the level of intensity on motorway)
Did u try factory reset on all settings? Then hit Power button on your screen for 10sec to reboot unitI wonder why you haven’t got the air on fault? Never noticed any difference in my lighting intensity on the Motorway since I’ve had the car.
Exactly how it was for me, I changed the home/leaving light time to 10s and my wipers stopped working, so i put it back to 30s and done a full reset, everythin working, however i cant select the time from display, its stuck on 30s.No, but I’ll try it. It’s driving me nuts, just been for a short run & auto wipers aren’t working now.
