Rain/Light Sensor Coding MK3 FR
worleyg
41
9
I've just removed the humidity sensor on an FR with no convenience pack and replaced it with the combined rain, light and humidity sensor. After some fun with VCDS I know have auto lights and auto wipers. Despite enabling leaving home function it just doesnt seem to work for me. Can someone who has VCDS and the technology pack mind scanning their config for me? I'd be interested to know both the coding and channel map settings for the central electrics module. I'm sure I need to change another setting but my German simply isn't good enough to understand the channels in VCDS.
Many thanks
Graham
DEAN0
Old Git
Feb 1, 2006
5,359
348
Preston - UK
Many thanks
Graham
This any good ?
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011413605965
Coding: 0B000A42C20102FB0B244000B10403281000000000000000000000000000
Shop #: WSC 00049 770 00129
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_SE37.rod
VCID: 000F8F249B4C96216EF-8055
Slave 1:
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 140429 041 0574
Serial number: 140504092905
Coding: 0BC5FD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y14M05D26H04M57S44
Coding: 00095D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY140790TH2
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000059703803
worleyg
41
9
Yes that'a a help as it definitely shows a slightly different coding on the Rain Sensor to what I came up with. Excuse me being cheeky but could you also perhaps export the adaptations for that controller? Its done from the Applications->Controller Channel Map menu of VCDS. It'll take an age to run though and need security access with code 31347 to read the values. I'm guessing there is something I've missed here as I had to change two settings to enable the rain function on the wipers and the leaving home function. I remember these were the straightforward long coding on the Mark 2 but have moved to the adaptations on the Mark3.
Thanks,
Graham
worleyg
41
9
Dam should have realised that was a bit long to post on here. I think the relevant lines all start with Comfort Illumination, maybe about 10 or more settings? If I could see those I'd be a very happy chappy.
Thanks,
Graham
DEAN0
Old Git
Feb 1, 2006
5,359
348
Preston - UK
(1)-Assistance light functions-Notbremsanzeige NBA active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms
(4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active
(5)-Assistance light functions-Fernlichtassistent Reset not active
(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung Not Present
(7)-Assistance light functions-Assistenzfahrlicht bei Regen active
(8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig kein_Hinweis
(9)-Assistance light functions-LS_Error_Ausgabe not active
(10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach not active
(11)-Assistance light functions-AFL Zeitverzoegerung 500 ms
(12)-Assistance light functions-Lichtsensorempfindlichkeit normal
(1)-Comfort illumination-Coming Home Verbaustatus automatic
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active
(3)-Comfort illumination-Menueeinstellung Cominghome 30 s
(4)-Comfort illumination-Coming Home Leuchten Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 18 lx
(7)-Comfort illumination-Leaving-Home Verbausstatus Enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 30 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx
worleyg
41
9
Many many thanks for that. Its all working nicely now. I'll write up a concise guide to this retrofit in case its useful for anyone else doing the same. Seems the coding is quite different to that posted elsewhere for the Golf Mk7.
pj106
38
Longridge
Did you have to put a new switch in for the lights as well? I thought there was an extra position named auto that is not there without the convenience pack?
