Radio Fuse
AdamRoutley
Use The Force!!
Feb 22, 2007
1,827
Walsall
www.myspace.com
I've been told now that for an aftermarket headunit there will be a couple of fuses that need to work, ignition etc. Basically mynew headunit has stopped working, yet everything else is fine including the original.
Jarre
5,365
11
Stockton-On-Tees
There may be a few depending on what you've spliced into. My head unit was set to ignition live through the air con unit. So when the fuse blew it was actually the air con fuse causing the air con and stereo not to work.
