just fitted my weitec gt coilovers all is great stance and ride the only problem is the steering is out not the tracking it straightlines fine but the steering wheel is at one side when going straight how do i fix this issue?
could be that the camber is slightly out and is causing it to be like it is, if when the camber is sorted and it's still like it get the tracking done to sort it out.
Just a quick one...it would be worth getting your tracking checked again in a few weeks. It takes a while for the suspension to settle so if they happen to do a free check then it would be worth getting it done just to make sure!
surprised you havn't had a bit more camber on the setup tbh. i run mine at 1 degree negative camber and it helps with the turn in and doesn't scrub the tyres off on the inside
