Questions About Carbonio...
-DT-
I want my SuperLeggeras!!
Aug 3, 2004
185
Bristol
I'll tell you something, Carbonio is a MAJOR pain the arse to fit- took me hours to get the filter on mine :)
-DT-
Aug 3, 2004
185
Bristol
tris said:
done mine in about 20mins half hour MAX:D
I clearly suck at modding cars then :cartman:
I just could not get the damn filter on with the pipe in place!
Pabs
5,936
Basingstoke
yep - i've cleaned my filter recently.
I take the filter and metal right-angle tubing out together, clean, and then refit - pushing from bottom up.
Piece of cake :)
-DT-
Aug 3, 2004
185
Bristol
OK that's where I went wrong :) I fitted the carbon pipe, then got under the car and tried to fit the filter- silly boy!
Pabs
5,936
Basingstoke
i fitted the carbon pipe first to - never moved it since - the rubber joining pieces and the metal right angle come off in 1 go.
Tallpaul
821
tris said:
how did you clean it paul?
lol, i didn't!
I decided I wanted a BMC CDA and sold the Carbonio after about 3 months.
The BMC just looked better under the bonnet:
Pabs
5,936
Basingstoke
i think he meant me... lol
I cleaned it using a k&n cleaner kit - cost about £10 from ebay.
Cleaned with the spray, some water. left to dry naturally, added a bit of oil.
Voila :)
tris
The Daddy
Feb 25, 2005
3,493
Kent & Track Days
www.leoncupra.net
yes LOL i have a K&N cleaner from my old beemer i am sure mine is well due a clean
how offen do you do yours?
i know on the bottle it says silly miles but with it being low down it will get dirty quicker
Pabs
5,936
Basingstoke
didnt have to remove wheel arch on mine - just jacked the car up slightly and managed to get it out through the bottom of the bumper :)
Took me 5mins to remove, but about 15 to re-install due to the awkwardness :(
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
I think thats a lot for an engine cover aswell,no matter how sexual it looks.
My Carbonio was bought 2nd hand with 2000 miles on it,so im gonna clean it before i put it on,then probably about every 5000 miles afterwards.
Only 20 days left till warrenty runs out so will be fitted then.
Still think i might put a cold air feed from behind the lower grill to it.
