Hi,
The MBE 992 ECU wont run with the DBW throttle. The MAP sensor we
supply is a 3 bar unit, so can run up to 2 bar boost.
The operate the ECU on a throttle position/engine speed based
strategy, so we dont run a MAF sensor as you say.
We run the ECU in closed loop 3D boost control (against throttle
position and manifold pressure) and it also trims boost according to
charge and coolant temp.
It can also take an input from a wideband lambda controller to give
full closed loop target lambda control.
Anymore questions please ask
Ben Leach
