programing of new key fob?
Aug 22, 2008
3,221
cannock
- Turn ignition on, and than turn it off after 3 seconds
- While holding the lock button, press the unlock button 3 times
- Car should now lock itself to confirm it has worked
- Turn the ignition back on for about 10seconds to confirm you have finished programing
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
what kezz said if you meant reprogramming the locks, if you meant immobiliser, then its dealer/specialist :)
richypanic
Seat Cordoba 2.0 16v SX
Nov 8, 2008
151
Aldershot, Hampshire
Can I say I had same problem. Keep, KEEP trying - it will come eventually. Follow the guides (there are a couple of ways mentioned on this site, cannot remember which finally got mine to sync) Just as I was going to give up, as if by magic, it worked again! Perseverence is the key (ahem...)
