Premature Dump (from dv)
sargey
Escaped mental patient
Aug 16, 2006
324
Weston-super-crapland
Sometimes in either 1st or 2nd i hear my dumpvalve (forge re-circ) dump when im excellerating slowly.but then when i excellerate more and let off i can hear it dump again
Its strange, does anyone know why this can be happening
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Well it happens everytime you back off, i used to hear it do that.
One thing to try though for peace of mind is a throttle body realignment.
If you are still worried about the DV take it off and do the pressure test on the Forge website.....it's fairly low tech (Biro and fingers) but should tell you if it's leaking....if it is speak to Forge and they will send you a service kit......fairly rare they need a service though
Pabs
5,936
Basingstoke
pretty sure that exactly what they are supposed to do.. :)
If you have an induction kit fitted, which is what your sig says, the chances are the noise you are hearing is air being sucked in through the kit, and echoed up the intake pipe... rather than the DV "dumping".
