It's that time of year again where map updates are available for mib2 that I tell you about using the workaround method. The map updates for mib2 standard are good for all VAG cars worldwide....
FL models use Mib3 connect services for the updates, although there are files available which might work for people out of contract. See this post if you want to experiment and report back
The old release should work straight away. Failing that the new release with the old release overall.nds from year dot. Failing that try the new release with the overall.nds that came with it. If that one works it means your unit had the life time navigation FeCs on it. The production issue...
www.seatcupra.net
Navigation unavailable
Hello, I purchased a new Ateca FR 2022 and the navigation is unavailable (country regulations I guess) Can this be somehow activated? Hardware: H56 Software: 0809 Thanks :)
www.seatcupra.net
