Powerflex Lower Dogbone Mount Insert Kit - Rattle
Holdup
314
27
Kent
Apologies if there is already a similar, I’ve had a look but can’t find any information.
I fitted a Powerflex Lower Dogbone Mount Insert today with a new bolt, torqued to 130nm + 90 degree but I now have a rattle about 4k rpm to redline when accelerating hard, if I accelerate slowly or just drive along it doesn’t happen, I was expecting some vibration and there is a small amount, I was thinking leave it a week and see if it beds in and if its still there remove it and drive without it and if that cures it just leave it out, just wondering if any was has experienced similar and found a fix?
adam davies
347
144
I havent had any vibration at 4k. Only vibration felt is at idle or reverse gear. Are you sure yo put the correct insert in as there are two versions not including the durometer/color
Holdup
314
27
Kent
I’ve got the idle and reverse vibration which isn’t too bad, the insert went in with no real issues, was a bit stiff but was the right one I checked it fitted round the mount before pushing it in, its weird it only happens when accelerating hard, I drove down the motorway at a constant speed and not a single rattle, I’m wondering if it’s exhaust related, I’m thinking I’ll just remove it tonight.
Hi Holdup, I've just ordered one of these, do you have the part number for the bolt by any chance?
I got the part number from the guide section on here, its N912 010 01, I checked before fitting and both bolts looked the same
Reactions: Woody_72
