I've had this suggested to me as a possible remedy for the Bluetooth phonebook problems with Symbian S60 phones, can someone with an N95 or similar have a go and see if it works with the Leon MFD?
What you need to apparently do is to transfer all the contacts to the car by using the following sequence:
In Contacts, select Mark all,
Send Business Card
Via Bluetooth
etc...
Only thing I am thinking is that I don't believe the Leon has a phonebook as such does it, only what you create using the voice commands?
Obviously it won't pull missed call / recent call data but it'd be a start if it does work.
Rob
Send Business Card
Via Bluetooth
etc...
Rob
