Possible alternator woes?
magicoi
254
Lincolnshire
04 plate Cupra TDI :)
for the last 2-3 months my ar has got a little noisy lets say. With no revs turning the steering wheel i get a horendouswretching noise from the engine. With revs no sound at all. It also happens on full lock, low revs, like when parking her.
Im told that the alternator has a clutch system on it which could be almost at its end. I have been quoted £300 to supply and fit a new alternator to 'see if that sorts it'. However im also told that it could be the air con system instead but no way to find out for sure without changing parts. BTW makes the noise if A/C is on or off.
No problems whilst driving and the power / delivery syestems are all a-ok.
Anyone had alternator problems? Or changed one? - How much did it cost you.
Thanks [B)]
sockpuppet
837
I had my altenator clutch pulley done a couple of weeks ago, the part was £30 and its quite a common fault. I had the tensioner and belt done at the same time as they had done nearly 90000.
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
I'm guessing you mean engine idling, not engine off ???
That sounds more like the power steering pump. It always complains at full lock, and you are told in the users manual not to hold it on full lock for more than 30 seconds (I think).
If I were you I'd get a second opinion, from an independent VAG specialist if you can find one close to you. £300 for a part swap "just to see if it works" is outrageous - they're asking you to fund their learning curve. Only agree if they will change the alternator back and refund your money if it doesn't make any difference.
Since the noise is associated with turning the steering wheel, I'd look at the power steering pump first. It's driven by the same belt as the alternator and a/c compressor.
magicoi
254
Lincolnshire
Sound advice Mutley, thanks.
I did mean when idling as opposed to the engine being off yes!
I wasnt referring to the noise full lock gives you, it happens when i turn the whhel from the off. Think i could have worded my OP a little better!
Sockpuppet - Thanks for the advice also, i will look into this. Id be chuffed to bits if thats whats gone as its a cheap fix!
-LeonFR-
Hello there,
I've got a similar problem as of yesterday, but I've recently had the cambelt/waterpump/alternator belt changed and I'm pretty sure it's the alternator belt slipping. I'm taking it back to the garage on Monday for a tighten. Yours could be just the belt too - when idling if I turn the wheel it makes a horrible flapping noise :blink:
magicoi
254
Lincolnshire
I did ask a VAG specialist, dont want to name names unnecessarily so i wont but they are based near Peterborough!
They suggested the alternator , air con pump etc.
Where is the alternator clutch pulley and how would i know if thats whats causing the problem? Pics would help if anyone can take a snap!
Thanks, its really starting to bug me and its an embarrasment in car parks!!
hughes86
159
manchester
i had this problem with mine, it is the automatic clutch on the alternator pully, on the pully there is a black cap flick this off and the inside of it will be brown and smell of something burning. fitted the new pully now the problem is sorted. hope this helps, as said before it is a common fault
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
I guess the answer is yes, but would the clutch failing disengage and stop the alternator from charging?
magicoi
254
Lincolnshire
Well, i pulled off the plastic cap from the alternator belt pully and everything was nice and clean inside :) So thats good,
Problem is stilll there though unfortunately. i dont really want to have to get SEAT to look at it but as a VAG secialist who is well known on here cant diagnose it i may not have a choice :cry:
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Mine alternator gave up the ghost on Thursday.
When the engine is running hold a screwdriver and put the end on to the casing, that will tell you if the bearings are shot or not, mine were :)
Obviously be careful :)
hughes86
159
manchester
not fitted one myself as i know someone at seat so they put the pully on for me as i got the alternator off. took them about 2mins by the time i had payed for it i had the alternator back in my hands. would be cost affective if you can get the alternator off yourself
ltwilson
Had it sorted today. Took the guy 2 mins and only 10 mins to take off and put back on myself. Problem solved.
Degsy
212
Merseyside
sorry to open this up again, I have I think a similar issue noise wise, been advised could be pre tensioner or alternator clutch pully.. itwilson if you are still around what did you have done the pully.
thanks
D.
ltwilson
It was the alternator clutch. Cost me 50 for part and paid a garage 5 to fit as he had the tool required
