Poror Radio Reception??
Steve`o
I have just bought a new radio and have noticed poor radio recepion on fm channels.Seat have said about fitting an amp in line with the aerial lead.Tried that -no better.Have also tried a new mast and aerial base as well.:confused: Has anyone else this problem.I plugged an aerial unit into the radio and held the aerial outside the car and the reception was fine.I don`t fancy taking the head lining down unless i have too.Cheers.
prc
Sooty Meister
The OE aerial has a wierd amp/signal lead. I'm pretty sure i've seen some normal radio (for aftermarket stuff) to VAG aerial adapter.
Pabs
5,936
Basingstoke
yep - you'll need one of those ^^^ as pointed to - halfords charge about £18 which is silly - ebay etc should get one for about £12.
Certainly improved things on mine. Shorter aerials also don't help, so if your aerial is a stubby or whatever then the std whip-type aerial will give better reception.
Other than that, I just make sure RDS and auto-tune are enabled and I don't have a problem.
Steve`o
My car is an LCR 05.The head unit is alpine.It was a genuine seat part(amp).The aerial mast and base are genuine parts too.The amp only increases the general sound of every thing(distortion included).??
Steve`o
Just checked out that website.It looks very similar to the seat unit.
Steve`o
As far as i know it wasn`t damaged.Car did smartnav fitted before.Unless they did some thing when fitting this.Since fitting the base and mast i haven`t tried the amp again.Will give it a go.
Steve`o
Have just had a go.I noticed the small pin in the aerial lead was way too small for the aerial hole in the radio lead.I opened it up to fit better and re-connected the amp. So far so far good.Fingers crossed.
red-27
had this with my last car did the same as you Steve and was fine for years
