Popping sound
Aug 22, 2019
7
When I go to parallel park or turn slightly I hear a noise like pop.. pop pop? Anyone had this issue , it’s doing my head in
Aug 22, 2019
7
I’ve checked the spring it seems to be sitting correctly . I’ve just changed the steering rack thinking it was that but noise is still there
RUM4MO
8,075
1,103
South Scotland
Easy enough to check if it is the spring top/top bearing problem, get the front up onto stands and disconnect the TREs and move each wheel through its normal arc of travel, any "bad stuff" should be felt by doing that. As you said though, sounds like something else, spring top/top bearing problems usually only give out a single PING at a time.
