Polo rear wiper conversion
MarkTDISport
the parentals have bought me some mods for crimbo, everythings straight forward (i hope lol) but i' m having doubts about fitting the polo rear wiper. i read on a couple of threads that people have had to do abit of 'fitting' work. would anybody be willing to make a 'how to' thread in this case, or is their one available that i have not found? apologies if this is silly but i dont want to be going into fitting the mod heavy handed and having to hand out money i shouldn't have to because of my brut force approach lol
Blanco92
www.racedriversinc.com
Apr 11, 2010
2,496
Bournemouth/Cheshire
+1, would be really grateful if somebody could publish such info!
As far as I understand the washer cap needs to be sanded down to stop it scratching the rear screen, however how much sanding is required... I haven't a clue!
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
I have fitted 2 and never had a problem with the washer cap, seemed exactly the same to me. Dead easy mod, only hard bit is removing the old if its been on awhile.
Neo
Fool member
Mar 24, 2009
881
As said sometimes it`s not required to "fettle" it when fitting but mine did. Blanco got it right it`s the cap that needs filing.
So when you get one, first fit it without the cap and test it out.
Then fit the cap and see if the bottom of it touches the glass.
Or if it squeaks when working then the cap is rubbing on the glass and will need to be filed down a bit. Don`t let it squeak for too long or it will scratch the glass.
This is the cap upside-down, just take a file to the entire bottom edge as shown to take a mm or two off.
Lippo
YNWA
May 8, 2006
395
Formby
I had to file my cap down slightly. You can file a bit off, fit it, check for contact and if necessary, file a bit more. It's dead easy to do.
Sep 3, 2008
873
Buckie, Moray
Mine was ok without filing, went straight on ok. Must be a hit or a miss really, just go ahead and try it. Old wiper needs some persuasion coming off though
Veyron
2,307
Birmingham
Mine needed a load taking off the arm as well as the cap, just take the cap down so it's the same size as the standard one and for the arm if it rubs just take enough off, but don't keep testing it as mine scratched due to too many trial runs :(
Neo
Fool member
Mar 24, 2009
881
Yeah mine too:( I probably should have put sellotape or something on the glass while testing.
Neo
Fool member
Mar 24, 2009
881
Or as you say take the cap down to the same size as the standard one? I did`nt think of that.
MarkTDISport
cheers for the help fella's, you have saved the old and new wiper arm the brut force approach lol
apologies for this but anybody with flip key experiences could you have a look in the flip key thread and provide abit of help please, cheers lads
