ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
another update:
Intercooler mounted: bungies not perpanent :p
spot the intercooler - very stealthy
Close up you struggle to see the intercooler. pipework tucked up behind bumper
Charge pipework getting built up (deblinged satin finish)
SEM Gen1 manifold on there with its R32 t'body, muchos tight fit as is everything on this install.
we're getting there. it does'nt look like much for a whole weekends work, but these builds are on-off-on-off-on whilst checking the pipe work fits, other parts still fit, before final tig welding things together. full 63mm pipework from turbo out.
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
what diameter are the bends you use? currently making a set for a friends car. can you get 15mm od stainless 45degree bends?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
have a browse thru Aalco fittings hooch - thats where I have bought most of my fittings previously.
for water pipes to and from turbo, 3/8" Stainless tube I use, which I tube bend to shape from lengths I have here.
http://www.aalco.co.uk/
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
some long overdue updated piccies..
chargepipework 95% complete..
As much as possible is done in hardpipe. longest single piece of chargepipe I have made yet, lol.
keeps joiners to a minimum.. eveyr join is a possible weakness/leak in service. just 4 joins in this lot and 2 hardpipes
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
couple more.. final oil drain and coolant feeds..
off the car again prior to sending to Zircotec for ceramic coating.
