Plug and play amplifiers (JAYKS)
paskahata
18
8
Finland
Planning to upgrade the sound system of my 2021 Leon PHEV. Planning to install an plug and play DSP amp straight in to the OEM system of the car. Maybe some damping to the doors and even new speaker at some point.
While googling around, Audison, Match, Focal etc were the usual amps suggested, but then stumbled on this german site selling some interesting looking gear.
Has anyone had any experience with these amps?
Plug in straight to the Quadlock connector, even support adding an passive subwoofer without needing extra power from the car battery?
These MK4 Leons have a center-channel on the dash, how would that affect the outcome, as the Jayks has 4 (mains) +2 (subwoofer) channels.
Seems like too good to be true. Leon KL is in their list of supported vehicles but somehow the site looks a bit scetchy..
EDIT: Well i ordered one from eBay. Someone has to try it :)
The seller was very responsive and even checked via VIN that my car is supported. Still have to find a subwoofer that meets the specs. Seller told me it should be 4ohm + atleast 90db to work.
I think ill go with this Helix K10 SE.2, even it has ”only” 88bd effinency. Should still work eh?
paskahata
18
8
Finland
Greetings from Finland!
I just installed the amplifier. Took 2 hours. Needed to remove the glove box to get my hands on the MIB3 system. Amp came with plug and play harness, so connecting is was very easy. Hardest part was getting the long silver plastic trim back on, as i removed it all. Easier would be just letting it hang in there like in some YouTube videos.
Took the wire harness under the passenger seat (left hand drive here). What is that metal thing under there? Some kind of voltage converter maybe? Is it missing some cover or so?
Still have to build some sturdy case for the amp somewhere there. And still waiting the subwoofer to arrive.
Just took a quick test and oh my what a difference even without the sub. So much more power from factory speakers. Imaging is top notch! I am satisfied 🤩
Reactions: Alsi
paskahata
18
8
Finland
Succesfully installed an subwoofer to my Jayks amplifier. Gladen RSX10SB.
Quite pleased with the sound now. Mids are a bit off but i think putting some insulation to the doors would help a lot with that. That would be the next step, maybe while on it, some new speakers / mids would be easy to be changed at the same time.
What are my options if i want something plug and play? There seems to be very little info of the OEM speakers these Leon eHybrids have? Some say these are 8”, some suggests that the normal 6.5” would be suitable.
For MK8 Golf there seems to be many options, but does it have the same speakers than this MK4 Leon?
