Please help!!
Goodst4r
8
Recently brought a mk2 2012 Leon supercopa 2.0 diesel, had the car for about a month and a flashing coil light appeared on the dash. This happen once then didn’t see it again for about another 800 miles
It’s now back and on every time I use the car but I don’t seem to have any power lose like I’ve read in other threads. I read the cars diagnostic to try find a fault code and it had none! Then today my engine management light can on but still no power lose or fault codes!
Please if anyone can help as I don’t want to take it to seat and be wasting time and money for then to look for a fault code I know isn’t there to then just start replacing random bits to “see if that works” and continually be going back and forth to the dealer
brian1912
73
Have you checked your battery in a previous car I had the battery was done was pinging up random lights on the dash ?
Goodst4r
8
Not checked the battery I’ll give it a clean and tighten up tomorrow. But could itnreally be that? As it doesn’t seem to have any trouble starting
adon30
156
Brummm Brummm
It is that time of year where weak batteries start to fail.
Mine had a couple of occassions where it wouldn't start properly. Other times it was fine. Changed the battery shortly after that and been good for the last year and a bit.
Check the connections and grounding are all good
brian1912
73
Mines was a dead cell so visually looking at it you couldn’t tell only when it was tested it showed it was failing
Reactions: Goodst4r
lewisb246
Check brake light switch had a case where it was that also try get it plugged into vagcom had another case where it was dpf related
Sent from my SM-G965F using Tapatalk
