Hi all,
I had to get towed off the motorway yesterday cos my car lost all power while in the fast lane, and now wont start .
Basically just died, like the engine had been turned off, backfired once (or sounded like it) when I put my foot to the floor on the accelerator, but oddly kept the stereo going and all other electrical functions. Now it won't start at all. The engine turns over, and sounds like it really should start, but just wont.
I've run Vag com, and the first time round the result shows:
VAG-COM Version: Release 409.1-US
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01: Engine
Controller: 6K0 906 025 C
Component: SIMOSöSIMOSIMOS 4S
Coding: 3502
1 Fault Found:
00513 - Engine Speed Sensor (G28)
16-10 - Signal Outside Specifications - Intermittent
Readiness: N/A
Address 03: ABS Brakes
Controller: 3A0 907 379
Component: ABS ITTAE 20 GI V00
Coding: 06406
Shop #: WSC 11111
No fault code found.
The 00513 was due to me shorting the speed sensor by accident while installing a navigation unit, which caused relay 30 (ECU?) to get extremely hot and then 'tick'. When it did this, the car just stopped as it has done now. When the relay had cooled a little, it would go again.
I didn't get any further noise from the relay or problems with the car dying after I moved the speed sensor short, and it has worked fine for a week before dying yesterday.
I cleared the fault codes using VAG, and have re-run diagnostics which now reports no error on either of the above addresses.
I am completely at a loss as to whats happened, and why it wont even attempt to kick into life. Its like turning over an engine with rubber in the spark plug gaps. The only thing I can think of is the fuel pump - no fuel, no go.. There's plenty of fuel in the tank, and all lights work on the dashboard etc.
I've checked all the belts that I can see, and also the timing belt, which all rotate fine.
If anyone has any suggestions, I'd be eternally grateful and if by any fluke anyone fancies helping now, I'm around all day. I can't go anywhere, even if I wanted to...
Thanks,
(praying that someone can help)
Nick
Address 01: Engine
Coding: 3502
1 Fault Found:
Readiness: N/A
Coding: 06406
Shop #: WSC 11111
Thanks,
Nick
