I had the same problem on mine. Found it was running lumpy.
Replaced it with a creationsmotorsport one off ebay. Took 20 minutes to do. Scrapped the old clips put jubilee clips on. Perfect fit.
an oil catch can mate, them pipes are prone to failure, check the pipes under the inlet manifold too as they go hard and crack/split, if you fit a catch can then you get to bin these hoses and all the oil vapour that would normally run into these hoses will just stay in the catch can instead of going back into the intake system
i have a spare catch can pipe kit, 2 metres of oil pipe, a t piece and a elbow piece up for sale, all u need is a catch can then
