Pinking/Pre Ignition
Redmistracing
Hi,
I have a 1999 T Reg 2.0L GTI (Logbook)/Cupra Sport(I Think) all standard, but I'm getting some pre-ignition/pinking at 2500 rpm under load. Was wondering if there are any usual reasons with this car; It had only started happening recently, so I don't think its a timing problem - Fuel consuptions 30MPG+.
Could it be a vaccum pipe gone or something like that? Blocked inectors?? what should i check for? Do these engines have knock sensors??
Your pointers would be appreciated!
Tim
Redmistracing
Hi, thanks for your replies.
How easy is it on these cars to do the tappets, i suspect you have to take all the intake mainfold off as it goes over the cylinder head - this looks like a right pain! I'm not 100% its tappets but its certainly something i hadn;t had thought of!
Has anyone used STPs fuel cleaner to get rid of carbon build up etc? I have been told it could be due to deposits in cylinder or injector blockages.
Is the only way to retard the ignition a bit to remap the ECU and therefore would i need SEAT to do this for me? I can see a hefty bill if so!
Tim
