Ok, some pics and a vid...
All new parts to replace everything we removed...
Removing the downpipe...
TIP removed along with turbo heatshield and charge pipe...
Turbo off and changing all the oil and coolant lines with new washer, crush clips etc, notice the oil coming out of the turbo on the left...
New turbo in place and ready for the downpipe to be bolted back in place, all oil and coolant feeds in place...
Secondary air pump hoses which i removed...
The pump and the combi valve got thrown in temper as we couldnt get the buggers off.
Vid of the first small run after warming the car up and checking oil and coolant etc...
http://smg.photobucket.com/albums/v147/philwarren11/Cupra/?action=view¤t=K03sfitted.flv
I'll take some more pics of the engine to show how much as been binned soon.
After fitting the turbo a few things come to light, the fact that the exhaust and the TIP were badly fitted now means i have to replace the inlet pipe with a new one. This time i'll be getting Forge one for the car, fits better and works just as well, as for the exhaust a lot of exhaust paste was used when i refitted the downpipe to the cat back so hopefully it might hold it, but i'll soon see. Also i need to get a 22mm blanking plug for the TIP and a new silicone joiner from the turbo to the fmic pipework as the turbo now has different size outlet tubing, I need to also work out how i'm gonna sort out the kink in the charge pipe to DV... pic...
Next up will be usual stuff like tyres, plugs and cambelt and water pump change along with sorting minor things out like my busted window regulator and cd changer.
