Small boring update, im fixing all the small things wrong with the car at the moment, so ive picked up new slave and master cylinders for the clutch. My clutch pedal has never been right since i bought the car, causing the pedal to drop almost to the floor on occaision which i have to put my foot behing and pull it out. Hopefully this should sort it and give me a nicer pedal feel as the clutch seems to be causing slight grinding in reverse gear only when warm. Also need to replace the lift reverse bracket on the gear stick with a new one as someone bent mine forcing it into reverse ages ago.
Im also FINALLY picking up my second seat on Saturday, also ordered my subframe yesterday and i got the other harness and side mounts here ready to rock. So finally i can have a passenger!
But im tempted not to put it in yet and remove all the sound deadening first. Pics as usual to follow.
