PD170 Stuttering Problem Solved
jibba_128
298
Would this provvide any benefit to a standard 170pd tdi with no mods? And can it cause the turbo to wear quicker or anything??
MillsyFR
63
Linlithgow
I've got a pd130 FR Ibiza and I've got it mapped to 170bhp, I don't get so much of a stutter but in 4th,5th and 6th gear I get a sort of vibration/shuddering/grunting noise when I put the foot down. Sounds as though my boost hose is about to come off......even though it isn't. Any ideas? Would this gasket mods help or maby an EGR delete kit?
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Sounds like a DMF (duel mass flywheel) problem to me.
/dev/null
1,649
101
Did you use a T50 or spline? I'm trying to find out what spine size it is but haven't found a definite answer yet.
/dev/null
1,649
101
In the other thread somebody said that although the T50 will fit, it's not the proper size?
/dev/null
1,649
101
Received and fitted the gasket today (thanks Dave @ Sere). I was surprised at how easy it was to be honest, I'm usually useless with things like this.
I ordered one of these off ebay to do the bolts with and it fitted perfect - plus will come in handy in the future I'm sure:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320699926489&ssPageName=STRK:MEWNX:IT
The back bolt was a bit hard to get to without scratching my hands a nearby wiring loom (shovel hands here!) but with a long ratchet I'm sure it'd be easier. Plus I was doing it on a hot engine - it's the only time it's been fine weather for 5 minutes to do it lol!
The only thing I found was that the pipe wouldn't come away from the EGR very far (just a couple of mm) - didn't want to force it. So I got a kitchen knife and just flicked the old gasket off. Slid the new one in and fastened back up within a couple of mins.
So... has it made a difference!? I don't know is the honest answer haha! I'm going out later on which involves some town driving and motorway so will see how I get on and report back!
ash101
160
Neath
So... has it made a difference!? I don't know is the honest answer haha! I'm going out later on which involves some town driving and motorway so will see how I get on and report back![/QUOTE]
Dev what was ur verdict on the egr gasket mod.
Any update???
/dev/null
1,649
101
Car certainly does seem to be smoother on standstill. It's early days to say whether it's solved the problem I was hoping (intermittent) however early signs are good!!
Joec1
75
Wiltshire
anyone know where i can buy this from online? as i live miles fro the nearest VW/Skoda/Seat dealer... and wont have time (outise of work) to go and get the part in person.....
my symptom is a hesitation similar to being starved of fuel, while cruising at around 15-1900RPM, giving me the "learner driver wobble" haha.
/dev/null
1,649
101
Just a quick point, this will throw up a DTC - doesn't bring the EML light on, but the ECU complains a bit about it in readiness test etc:
Code:
001025 - EGR System: Insufficient Flow
               P0401 - 006 - Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 1
                    Fault Frequency: 4
                    Reset counter: 25
                    Mileage: 156374 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:27:55
             Freeze Frame:
                    RPM: 1984 /min
                    Torque: 88.0 Nm
                    Speed: 104.0 km/h
                        84.63 %
                        95.55 %
                    Mass Air / Rev.: 310.6 mg/str
                    Mass Air / Rev.: 457.8 mg/str
Readiness: N/A
AndrewJB
Aug 16, 2007
11,209
485
Maranello
**Update**
S4ark Performance are claiming to have a 100% Fix for this now, They are saying that the problem is Coding Related in the Siemens PPD ECU and that all of their Remaps from now on for the PD170 Will contain the new Coding
Because they have done this off their own back they wont release what exactly is causing the problem to anybody, Which means other tuners and VAG wont be able to update this on theres
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
**Update**
Fair enough for S4ark, its time JBS etc admitted there is a problem with coding and give some help / free coding update.
Although I must say I have no problem with JBS and the De-DPF code seems fine, but only the stutter which to me feels like a fueling issue to be honest but who know.
