A mate has a 2002 Passat PD 130, it all started when the car was idling, it started as a miss but when he revved it, it disappeared until it idled again and then it cut out.
It wouldnt start but would start with a tow but the engine had very little power and would only restart with a tow..
He left it to someone to have a look but when it was towed to the garage the car became ok again and was ok for 2 weeks and now the problem has returned permanetly..
i had a quick look today and when you switch on ignition you cant hear the lift pump in the tank priming, no buzz, just quiet..
Would the pump have failed? Or could it be a bad connection somewhere?
