Paranoid About MPG -130 Remapped Owners
maxcars1
735
Ok guys first and formost I dont want to get this thread harping on about loads of mpg figures, but just some guidance. Over the past couple of days I've had my timing belt done and noticed that my mpg is quite low; or is it:confused: - a timing belt surely cant cause this:confused:
The car is used approx 4 times a month as I have a work horse for commuting:p My car is mapped and running approx 175-180bhp. Drove to work today which is a 25 mile run and after about 20 miles the fuel computer reached 48mpg average at a constant run of 75mph. Yesterday in town approx 31mpg was seen.
So all you 130 remapped owners should i be worried about these figures:shrug: I'm sure i was getting around 50-60mpg before, but i will say that i've gone from a mapped 100pd to 130pd hardware and another remap hense why I highlight the issue to 130 owners. I'm staring to think MAF issues already, but need further guidance.
Kam
Prof. Myang Li - Yum!
Jun 6, 2002
1,738
South East
Before I had my car mapped, it used to return an average of 48mpg. After mapping, the mpg went up for a little while but now, it is about 46mpg.
A cam belt chage "could" affect the economy in the short run. I don't know how I find that little things such as tyres do.
BlackFR
1,724
Not too far away
My non remapped is churning out low mpg's at the moment. My cross country bash is showing 37mpg. Always goes lower than average this time of year!
keefy
344
An over-tight cam belt would reduce your mpg. If it is too tight, it can damage/snap the tensioner.
If you are concerned I would ring the garage, express your concern and get them to check the tension.
My Bro has a 1.6 Golf and the VW dealer over-tightened his replacement cambelt. A week later it broke the tensioner and he had to call out recovery. Luckily, it did no other damage (amazingly) and VW replaced it FOC.
Kam
Jun 6, 2002
1,738
South East
If the belt is too tight, it is noisy. There will be a belt whirring noise, which goes up and down with the revs.
I had this when my belt was changed and the monkeys had over tightened it so much that the tensioner had snapped/broke.
maxcars1
735
when changing the belt i think your supposed to check the timing with vag com or the like after the job is done, this could be the issue.
Can anyone check this to see if its defo say on Elsa:confused: Maybe worth asking just to make sure
maxcars1
735
sssstew here why on the PD ;) "Note to 1.9 PD (pumpe duese aka unit injectors) owners: You cannot nor do not need to set your timing electronically. There are no graphs published for the simple reason that the timing is set using a dedicated VAG locking tool when changing the timing belt" :)
Theres the answer
dasmith83
Formerly "Dave FR PD130"
Jul 1, 2006
602
Kent
thats wot happened to my mpg figures wen i got mapped m8. Sounds like normal to me...maybe its just my right foot tho :p
idge
i think its the time of year, mines dropped a few mpg recently. I don't think the cold air and high winds help the engine much. Especially seen as i go over the pennines every day
D-Power
110
Newmarket
Its important to keep checking tyre pressures at this time of year as the temperature drops they'll often be down a few psi. Makes a considerable difference to mpg and handling IMO. Every little helps....
dmjw01
Upstanding Member
Jul 28, 2005
442
Woking, UK
www.dmjwilliams.co.uk
On the contrary: Engines love cold air. (Except of course, for short journeys where the cold ambient temperature means it takes a long time for the engine itself to reach operating temperature.)
But in any case, we really aren't seeing cold air at the moment. It's ridiculously mild for this time of year - I'm seeing 12 to 13 degrees on the temperature gauge.
Oct 31, 2006
470
Lichfield, Staffs
On my journey to Uni this morning I only saw 51mpg. Before Christmas, I was seeing 56/57mpg as an average on the journey (at 70, motorway). This tells me the wind is affecting my MPG quite severely!!
idge
Ah but the cold(er) air is making the engine use more fuel cos the air is denser, so its quicker but thirstier.
i managed a 59mpg run earlier, but that was at 50mph all the way, grandad style
dmjw01
Upstanding Member
Jul 28, 2005
442
Woking, UK
It only uses more fuel if you put your foot down further on the "go" pedal. The volumetric efficiency of the engine is better with cold air. If you drive it at the same speed, it'll do better in cold air than hot air.
