Pads and Discs
jwfcms
384
UK Yorkshire
i have ordered mine from CRN on ebay, DS2500 front pads with 40 grooved discs, and exactly the same on the rears, ds2500 pads all round and grooved discs all round for the brembo's. Cost £ 350. Nobody could do a better price than this for this all round!!
havnt recieved them yet as they are waiting for the rear pads.
fluid change is easy to do. go to machine mart get a gunson brake fluid bleeder kit. you fill the bottle with brake fluid attach the line to your brake fluid resevoir which screws ontop like the cap, get a wheel and use the tyre valve which connects to the bottle. it puhes the fluid through using the tyre pressure. just start at the rear and open the bleed nipple on the caliper for a bit to the new fluid is flushed through clean. check the fluid in the bottle at all times you dont want to run the resevoir dry!
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
I've got these discs on at the moment..the 40 grooves eat pads pretty quickly - keep an eye on them! <12k miles out of mine!
andymac
i had my discs from these ! after 3 months they warped and after 4 months the replacment set warped ! i believe they are ebc discs that they machine grooves in !
i will not be buying from them again :censored:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
too many grooves imho
cheese graters
ds2500's for rear are not made the correct thickness either which is why I do not supply them on brakes I sell.
Crize
79
After some search and a discussion with Badger5 (thanx again, Bill) I went for ATE Power and DS 2500 (not yet fitted, however).
My understanding is that Brembo MAX are upgraded discs for street use, not necessarily sport versions.
I remember "SportLine" being the name of the entry level Brembo sport brake series.
http://www.brembo.com/ENG/HighPerformance-Brakes/CarsSportLine/
I also remember the sensation of dribble when looking at "GranTurismo Line", but that's sky-high for me now.
Cheers,
Crz.
PS
Sorry for tha late post.. This above was for BBoy82.
