redoubtable
Hi there,
My car (2003 Seat Ibiza 1.2 Petrol) has failed its MOT for high carbon monoxide emissions after the 2nd fast idle.
I don't have the exact figures, but the car has noticeably been using more petrol recently.
I was planning to get the oil, oil filter and air filter changed, add some additives, take it for a good spin and then get it retested.
But since then it has been hooked up to VAG-COM and returned the following errors:
Address 01: Engine Labels: Redir Fail!
Part No: 03E 906 033 P Component: 1.2l/4V SIMOS3 00HS4729 Coding: 00061 Shop #: WSC 06402 VCID: 2D5AD94BE7194670BA3 VSSZZZ6LZ4R048484 SEZ7Z0C21554072
Faults Found:
16804 - Catalyst System; Bank 1 P0420 - 35-10 - Efficiency Below Threshold - Intermittent
17511 - Oxygen (Lambda) Sensor Heating; B1 S1 P1103 - 35-10 - Performance too Low - Intermittent
Readiness: 0000 0000
So it looks a problem with the oxygen sensor. Can anyone tell me if this means it needs replacing, or might it be possible to mend it? And can anyone advise whether it will definitely needs doing or whether it might be worth just trying changing the filters, etc, first in an attempt to get it through the MOT retest? And if it does need doing, what will it cost?
Many thanks.
Faults Found:
Many thanks.
