Hi Guys,
I am still having this issue being the Engine module incorrectly coded.
This is my scan with VCDS Lite :
Address 01: Engine Labels: Redir Fail!
Controller: 03E 906 033 P
Component: 1.2l/4V SIMOS3 00HS4729
Coding: 00021
Shop #: WSC 47886
VCID: 2D2D8AB7F409
VSSZZZ******** SEZ7Z0D******
1 Fault Found:
18020 - Engine Control Module Incorrectly Coded
P1612 - 35-00 - -
Readiness: 1010 0001.
I have found this on the internet :
Address 01: Engine Labels: 03E-906-033-AZQ.lbl
Part No: 03E 906 033 P
Coding: 00061
Shop #: WSC 06402
VCID: 2D5A723BE766FA7600B-5148
VSSZZZ6LZ3R162346 SEZ7Z0B1903013
The engine is AZQ like mine and also the ECU part number and component.
can I swap my 00021 code to 00061 ? I also would like to fix that redirect fail message. what is your thought please?
I cannot find anything else . Ross-tech seems to warn that might makes the ecu unusable if wrong code is used ?
Many thanks
Coding: 00021
Shop #: WSC 47886
VCID: 2D2D8AB7F409
1 Fault Found:
P1612 - 35-00 - -
Coding: 00061
Shop #: WSC 06402
Many thanks
